Unlock Bios Password 6050a2930901-mb-a01 hp 830 g5 bios unlock
user60367
Toolbox
need help to unlock my bios.. thank you
  • hp back up.rar
that file is new and exact file for this model and should work
check it more
user60367
Toolbox
001: 爱修
002: iFix iFix
003: Serial number: ,PCB V1.80,Boot V1.00
004: >------------------------------------OK---------------------------------------<
005: Read timeout.
006: Retrying ...
007: Align to the bottom of ZIF,disable placed at random function.
008: Chip pins contact is detected OK.
009: Auto identified 21 ID is match with the partnumber.
010: The currently selected:W25Q256FV@WSON8 8X6, capacity: 256Mbits, 32Mbytes.
011: iFix 爱修网RT809F教程与软件会员注册 技术求助区 专业液晶维修 编程器官方网站RT809F使用教程 —— RT809F离线写8脚25芯片(主板BIOS、显卡BIOS、硬盘固件芯片等) - Powered by Discuz!
012: >------------------------------------OK---------------------------------------<
013: C:\USERS\LENOVO\DESKTOP\830 G5 UNPASS.BIN
014: File has been loaded, checksum: 16bits_0x6B27 £¬32bits_0x8AF16B27 :
015: Read timeout.
016: Retrying ...
017: Align to the bottom of ZIF,disable placed at random function.
018: Chip pins contact is detected OK.
019: Chip ID verification OK.
020: UniqueID:0x2F492C9F360868DB
021: Start writing chip......
022: Auto erasing...
023: This type of chip capacity is big, so erase time is take longer, please be patient!
024: Erase successful£¬Elapsed time£º49.02 seconds¡£
025: Start writing...
026: Write successful£¬Elapsed time£º27.67 seconds¡£
027: Auto verifying...
028: Verification successful£¬Elapsed time£º21.62 seconds¡£
029: Status Register-1 : 0x0 , Status Register-2 : 0x2 .
030: Elapsed time: 98.77 seconds£¬average speed of 679425 bytes/sec.
031: >------------------------------------OK---------------------------------------<
still the same.. :cry::cry:
user60367
Toolbox
try this one
005: Align to the bottom of ZIF,disable placed at random function.
006: Chip pins contact is detected OK.
007: Auto identified 21 ID is match with the partnumber.
008: The currently selected:W25Q256FV@WSON8 8X6, capacity: 256Mbits, 32Mbytes.
009: iFix 爱修网RT809F教程与软件会员注册 技术求助区 专业液晶维修 编程器官方网站RT809F使用教程 —— RT809F离线写8脚25芯片(主板BIOS、显卡BIOS、硬盘固件芯片等) - Powered by Discuz!
010: >------------------------------------OK---------------------------------------<
011: C:\USERS\LENOVO\DESKTOP\DR BIOS FILE\830 G5_NEW.BIN
012: File has been loaded, checksum: 16bits_0x957B £¬32bits_0x8ABD957B :
013: Align to the bottom of ZIF,disable placed at random function.
014: Chip pins contact is detected OK.
015: Chip ID verification OK.
016: UniqueID:0x2F492C9F360868DB
017: Start writing chip......
018: Auto erasing...
019: This type of chip capacity is big, so erase time is take longer, please be patient!
020: Erase successful£¬Elapsed time£º45.98 seconds¡£
021: Start writing...
022: Write successful£¬Elapsed time£º27.49 seconds¡£
023: Auto verifying...
024: Verification successful£¬Elapsed time£º21.75 seconds¡£
025: Status Register-1 : 0x0 , Status Register-2 : 0x2 .
026: Elapsed time: 95.34 seconds£¬average speed of 703897 bytes/sec.
also the same. auto on then blinking whte and orange light in charging light. the power lights on, in button. the fan run high speed..
even i force off it will on automaticaly.i will try again tommorow.. thank you admins and staffs.
Hosein Asadolahi
hi
if you programed bios with old backup and system still have problem in booting , i guess system have different problem and bios file don't have problem
you must check the voltages and other things .
example : check the components around the bios ic .
Since the device does not turn off , i guess io has a problem . maybe when the system is on you have Screwed up ;)
user60367
Toolbox
hi
thank you.. i will check it now.. let me show you the reading in oscilloscope.. i know im out of the topic in the section.. im sorry for that.. thank you for your consideration.
