How to solve' Warning!! - machine is not in committed state!
First of all' lets see why this problem happens :
This problem is specifically occurs for HP laptops and is a branding problem. Usually occurs when the system board is being replaced and the banding wasn't done correctly. There is a specific tool which is used to commit and lock the system board once replaced which is not publicly available. Also this problem can happen when the programmed bios is not exactly compatible with the motherboard or the motherboard can't read the bios file.
How to fix this problem ?
There are 3 Brands for solve this problem : Brand11 - Brand12 - Brand13
these Brands are different solutions to solve this problem and each of them are available in the HP Fix Tools folder.
It doesn't matter which method you use or it doesn't matter which laptop model you working with. you just need to try and check one method and see if its solve the problem.
Here is the methods and instructions which you need to follow them step by step for solving the problem :
Brand11:
1. Copy folder Brand11 to the root of the USB key formatted as FAT32.
Your USB key should have less than 40 folders and files in the root.
2. Goes to F10 -> System Configuration -> Boot options -> UEFI Boot Mode
-> Press "Enter" to enable EFI boot -> Select "Accept" -> Save and exit.
3. Press F9 then "Boot from EFI File", then select your USB key -> Brand11
-> Bootx64.efi -> Press enter to run startup.nsh
4. Follow menu to commit AMT and AT.
Chose 1 to commit VPRO with AT, or 3 to commit Non-VPRO with AT
5. Press 9 and then Enter key to lock descriptor and reboot the machine.
6. Press F9 then "Boot from EFI File", then select your USB key -> Brand11
-> Bootx64.efi. You should see the message "Pass!!! This machine is configured"
7. Reboot to F10 and disable EFI boot mode.
Brand12:
1. Copy folder Brand12 to the root of the USB key formatted as FAT16/FAT32.
2. Goes to F10 -> System Configuration -> Boot options -> UEFI Boot Mode -> Press "Enter" to enable EFI boot -> Select "Accept" -> Save and exit.
3. Press F9 then ìBoot from EFI Fileî, then select your USB key -> Brand12 -> Bootx64.efi.
Brand13:
1. Copy folder Brand13 to the root of the USB key formatted as FAT16/FAT32.
2. Goes to F10 -> System Configuration -> Boot options -> Boot Mode -> Choose "UEFI Hybrid" mode -> Save and exit.
3. Press F9 then ìBoot from EFI Fileî, then select your USB key -> Brand13 -> Bootx64.efi.
ENJOY !
  • HP_Fix Tools.zip
