File Request HP 650 G2
Dcomp
Alcatraz22
Premium Silver
I tried many files from the site but every single one just give a powerbutton light for a few sec when charger is pluged in. Original BIOS have next issues ( cant eneter the BIOS, system runining slow, CPU work only on 600-900Mhz instead) please help
  • MX25L12805D@SOP16_20251208_102219.BIN
send motherboard model
Dcomp
Alcatraz22
Premium Silver
pressing the powerbutton and nothing happend, behavior same as before.
that file is tested working bios
please check the hardware carefully
Dcomp
Alcatraz22
Premium Silver
Hi, so i replace a charging port because it was damaged and then the BIOSes start showing different behaviour, laptop starts on fan is spining but no picture. i also check hardware carefuly and everything seems to be fine. Do you have any other suggestion what to do
  • HP 650 G2 test ok.zip
last file also tested working file ! i got it from same working ok device.
Dcomp
Alcatraz22
Premium Silver
okay but is there anything to check more, i dont get it how the motherboard can be dead by changing the charging port
maybe its from bios chip itself
yes
Dcomp
Alcatraz22
Premium Silver
same as before, i will consider this as unrepairable. Thanks for helping
you are welcome
good luck in future works
