PitbullHellas
Hello i have black screen and only fans spin need bios for this model with dag7hamb8e0 rev.e motherboard , here is the dump bios.
i had try one time the c5 and one time i flashed the c6 none of them worked
all voltages are presentmaybe you need to check hardware
maybe ITE must be flash also?this device is AMD and bios file can't be cleared or edited
try attached file and if its not work again then you should check more on the board
okmaybe ITE must be flash also?
