File Request LA-6561P REV:2.0
rafetorpak
LA-6561P REV:2.0
e6520
Cihazda bir BIOS şifresi var. Şifreyi silebilir miyiz yoksa yeni bir BIOS gönderebilir misiniz? Şimdiden teşekkürler.
  • EN25Q64@SOP8 DELL 6561P.BIN
rafetorpak
password : vlk8qRwfZHcC3160
for some Dell codes press Ctrl-Enter, not Enter, when entering code into the BIOS
password is correct !
notice uppercase and lowercase words and numbers
try with external keyboard too
vlk8qRwfZHcC3160
lowercase v
lowercase l
lowercase k
number 8
lowercase q
uppercase R
lowercase w
lowercase f
uppercase Z
uppercase H
lowercase c
uppercase C
number 3
number 1
number 6
number 0
rafetorpak
vlk8qRwfZHcC3160
lowercase v
lowercase l
lowercase k
number 8
lowercase q
uppercase R
lowercase w
lowercase f
uppercase Z
uppercase H
lowercase c
uppercase C
number 3
number 1
number 6
number 0
Thank you for your help, but we are 4 people here, we all applied what they said to the letter, but it gives an error, is there another solution?
rafetorpak
very good
Hello, my password process has been solved with this bios file, but there is a problem right now, I can't activate it from Wifi and lan bios, USB is not active, I say activate it from bios and save it, when I enter the bios again, the setting returns to the beginning (I changed the bios battery, it is intact)
this problem is related to windows
not bios
and also you should make correct time and date
rafetorpak
not bios
No, the date and time are correct, Windows doesn't even see the flash memory to install it, even though I activate it from bios, USB, Wifi, and ethernet biostan, it does not register, it goes back to the old state, I think it can't be changed without the administrator password, I'm trying to put a password, it constantly gives an error when setting a password, if there is another working bios file from you.
