code I get in bios is 1yxx2zw2-8fc8
Ser Tag# 7SF2Zw2
Ser Tag# 7SF2Zw2
Finty is the all-in-one software for laptop repair shops — print repair ticket & invoices in 21 languages.
here ya goPlease send the BIOS backup which has password.
There is no password in this file.here ya go
Is there any way you could make this file an executable? The bios lockout has also locked out any usb use at boot. Only HDD is availableyou should program 32MB file :
OK, full story. I'm an independent computer tech (retired). Received laptop with no OS, BIOS locked. Got SSD up by using windows to go on it (did separately). However, cannot boot to usb, or anything attached to usb due to admin restrictions in bios. All I can get is a system code of 1yxx2z2-8fc8 when trying to unlock. I'm almost bald from pulling my hair outyou should program the file with programmer device
Is there a programming device where I would not have to remove the chip?alright
the only way to unlock the device and use that file is programming it with programmer device
there is no other way unfortunately
NOIs there a programming device where I would not have to remove the chip?
OK, thank you for all your help. Looks like I'm taking it to the range.
