Please send motherboard model.
Is this ok? Please advise and thank you for your help... Herb
Hi - attempting a UEFI boot USB - will update asapI tried with the Phoenix Winflash - it won't take the bios (zip file) and throws an error about the build "Please select the correct bios" - should I be attempting to flash with another program and/or utilize a force switch? I am currently using Phoenix Winflash 1.5.66 and also tried with 1.4 version Phoenix Winfash. Should I attempt to build a Dos USB boot and load the Dos version? I see you can script an .ini file with switches - just wondering what you recommend? - Thank you Salimeh again for your fast response.
RE: Lenovo 320-15AST ideapad laptop - bios locked
Hi - is there a way to unlock the bios? I got a replacement motherboard from vendor but it has bios lock. Please advise - and thank you for your site.
At the end of this journey is this: I had a 2nd damaged 320 board and followed a guy on YouTube that de-soldered using flux only and re-soldered using flux only. I removed the bios chip off that damaged board and installed it on this locked 320 Lenovo Ideapad AMD and I am in the bios! - I just stopped in to thank all of you for trying and I learned some good things here by stopping in and subscribing to your website - Thank you all for taking the time to try and unlock the 320 - My bios clip has not arrived yet so I went through this process just to see if it would work. I had nothing to lose - Thanks again - !
Holden53 , Vahab Hemmati , Salimeh Bolboli , applix , user6389 , Ali Shaikh , Anys , vicsem73 , boxshifter , Electronica360 , Erfdu77 , andrei , mishcatm , emillyr , b-slayer , Doug1975
