RepairDashboard Preview
Ads
The Best Software for Laptop & Computer Repair Shops
Run your computer repair business more efficiently with RepairDashboard. Track tickets, manage inventory, and handle accounting — all from one fast and cloud-based system built for technicians.
File Request macbook pro A1706
try attached file
  • macbook proA1706_Unlock.zip
GSM MULTIMEDIA PRO
Test pins..
Test pins OK
Read ID Flash..
JEDEC ID: C22017
SFDP compatible
Vcc Supply Maximum Voltage: 3600 mV
Vcc Supply Minimum Voltage: 2700 mV
Start erase in: 05/08/2020 13:58:20
End erase in: 05/08/2020 13:58:20
Erase OK
Start blank check in: 05/08/2020 13:58:21
error
address: 0
buffer: FF device: 0
Blank Check false
give this error
GSM MULTIMEDIA PRO
the file work no need to open just used a deferent programmer ch341A with EFI cabel AND WORKING PERFECTLY
PROBLEM WAS THE SVOD3
