OK, give me other options, any voltage and da of power sequence is ok.. but only notebook not start, not short on cpu or any component, any component tested, new original EC (programed over KB conn writing, reading, compare ok), new bios chip writing on RT809H reading compare OK, all power seq is ok.. only problem with dump... give me other options...Hi
if all files are not working maybe problem is not related to bios
original EC damaged (short) original bios damaged (short) not ussable..send original bios and ec
In this notebook find 3 broken parts, EC (ENE KB9028Q), Bios (MXIC MX25L6473F), and charger ic (BQ24780S), any parts replaced, charging worked, discharging too but only 0,02Amps consupmtion, after power button only blink Caps and Power LED..original EC damaged (short) original bios damaged (short) not ussable..
hmm.. ok díky za odpověď.. mám tento soubor, ale MS-16P1 odlišný od MS-16P11 (jiná deska a další schémata atd..) pro mě není použitelný :/tento odkaz je testované pracovní soubory
MSI GE63VR 7RE Raider MS-16P1 MS-16P11 VER 1.0 Bios
MSI GE63VR 7RE Raider MS-16P1 MS-16P11 VER 1.0 Bios-Ver E16P1IMS.10B EC-Ver 16P1EMS1.105 VBIOS 86.06.4B.00.63dr-bios.com
by chance for another laptop. datasheet for SY8288BRAC? shouldn't you?
yes i need datasheet of SY8288BRACyou need datasheet for SY8288BRAC ?
there is no exact datasheet for that chipThis datasheet is SY8286A this is different chip, different pinout, different everything.. SY8288BRAC have pin13 FB SY8286A is 13 ILM not usable for me :/
Ne ne.. díky za snahu, ale pro mě to není použitelné :/ ale ok.. vyřešil jsem topro tento čip neexistuje přesný katalogový list
myslel jsem, že je to možná podobné
SY8288BRAC is different pinout and parameters over SY8286A diferent pin location, diferent parameters.. not usable..What?
yes I know, it already occurred to me..Unfortunately, we don't have the exact diagram for that model.
