YA m using that software only in that when i go in first option (set system identification) its showig write-protectedyou need to put the file in below link to a flash memory device and boot the laptop with that
then you can fix serial and uuid
old dump attachedNOT ABLE TO CHANGE SERIAL NUMBER
i am using that bootable file only for updating serial number. but the bios is having write protection i sent u the videos also. ur bios is not even turning onn the laptop .the only way to fix serial number is that file i sent in first reply above : post #2
that one should work and there is no other way
this file is working perfectly but late display 25sec . can u clean this file n sendtry this new update bios :
