if you did exactly like guide , system must have back light . maybe one wire not connected correctly , check every connectionhey bro, i did another one, exactly like the first one. this one has display but no light. What should i do in this case?
ok i will checkif you did exactly like guide , system must have back light . maybe one wire not connected correctly , check every connection
hi, we can disable gpu without desoldering gpu chip. we have to just reprogram bios and cut resistorYes it works but you need skills to do that. its very difficult
yes , that solution work but when you update os , bios will be updated and display goes .so converting with that solution you said is not a proper solution .hi, we can disable gpu without desoldering gpu chip. we have to just reprogram bios and cut resistor
In this article we’re going to show you how to convert MacBook Pro a1286 2011 - 820-2915 Dis to UMA by applying some simple changes.
All you need to do is to remove Graphic Chip and connect wire exactly as shown in the pictures.
yeshello sir is this method can use in 820-2914 17 inch a1297 model? pls let me know friends
its similar .can we have the schematic of converting dis to uma for A1297 820-2914-B
you can use boardview .but some of rezistors are not at the same paces
Hello, I have a successful job done but red over shadow other colors.
What can be the problem?
bro i have a case like this. how did you solve the red color?Hello, I have a successful job done but red over shadow other colors.
user48122 , , Oscar Sanchez , I4itsolution , Pozitif , user6389 , SSV , user60290 , user3333 , user6702 , pankajbiyani , user55731 , user46292 , Tara Laptops , Electronica360 , Tufan Teknik , Copper Lines Infotech , longskytrg , Tech-house mile 17 , CZ027 , , user55973 , mrwahab , Support Staff no.1 , Hosein Asadolahi , vicsem73 , screentechs , Javed Anwar , user60406 , teknikbilisim , , user61870 , AB WALI , user2898 , Cyberlero1 , armanuddin , user61849 , Cucuk Sugiarto , Androtech , marufpatowary , Yaser saeed , , PNad , Anwar1982 , user41457 , user9979 , user17261 , user57871 , Mater , R K , user30915 , Dr-bios-2022 , Padam , nassarraouf , sreeraj , daengrani , iannakano , ProtocalElectronics , user57497 , mshanasm , user60411 , iphone one , babalsalama , zinmina , Trivik , user651 , mista , NDSsource , Mickeymad , opista , Comsmile , Faizal , user30692 , Dlspro , user19935 , computerkingcoburg , CTS1983 , abu jullia , notebooktradee , thagna venancio de olivei , Ramiro Ramos , hive13 , angrej224 , user61975 , rudy90 , MAX8899 , user129 , user54326 , ranjan8750 , user54338 , famory , kamalbam , gayan123 , user9544 , kto1983 , user34262 , saibrij28 , CoinTrader , data2022apl , kubilaykaplan , Jose penson , rangadvice , user30168 , rejiambalil , b2btechnician , berkahbintang888 , user24229 , ranjit shrestha , Roollice , user26471 , ICElaptoprepair , lorenzo777 , alfredposadas09 , Rohit suthar , o637 , wordimont , Kliavas , Willie , endurance albert , Technology , destinycenter , amir7417 , compulab , user50857 , Shvan , miltisp , afonso , dacami111 , nitishsahani , luisenriqueecheverria , Abdul Qadeer , alexcanario , a999s , Prozon , Kanini Technology , EkoSetyono , user48165 , jules , Ujjwal , 2yquality , LowVoltage , Kads , oswaldo mendez ramirez , user55677 , mariusz35 , ebubekir soyalp , EdwinUsady , Elliottcit , jericodilan , maximooos , verhaegen , R3tr0Batuhan , Cyberlero2024 , archaacus , umar kha , AbangDul
