File Request Asus X556UV_MB REV.3.1
user61596
isa198585
X556UV
R558U
Cant reset CMOS cause its BIOS Battery not on board.
I need my BIOS but with default settings, or a New one, I find some files on dr.bios.com but its not work.
I only changed boot settings, and after restart, it show invalid screen.
  • Original_Need_Reset.BIN
  • X556UV 3.1.zip
user61596
isa198585
Laptop doesn't power on with this file.
can your say me, ho to reset CMOS on this board?
  1. Turn off your computer.
  2. Disconnect your computer from the wall outlet.
  3. Press the power button multiple times to clear any capacitors.
  4. Find the CMOS battery on your motherboard. ...
  5. Gently remove the CMOS battery. ...
  6. Wait a few minutes, then replace the CMOS battery.
user61596
isa198585
Sure, I know, but this board doesn't have CMOS BATTERY, I searched 10 ming on this Battery, but it doesn't have it.
then how can i help ?!
in these kind of devices CMOS is on main battery
you can remove main battery and it will be reset
if you want to change windows and if you trying it with flash memory maybe its setting are different as GPT or MBR
it should be same
user61596
isa198585
NO, I get this Laptop, withh error, no boot in to Windows.
I tryed to Instal a new Windows.
Disbale Security Boot.
Enabled GSM, F10 Exit and Save, after this, I get this image, see Atachment.
I think when I reset CMOS, all Settings will be back, and I can give this Notebook back to Custumer.
as i said in this device CMOS battery is on main battery
