Okay i will try
send me full laptop model and serial noHello my friends when update the bios after flash it i get solid led charge and no boot nothings happened i tried to update the bios because nvme m.2 cant show in bios after this problem i tried to reflash the bios with original dumps it worked fine what is the problem. Note: i download the bios update depending on the serial number of the laptop please help.
latest update files for elitebook 840 g8 :Hp elitebook 840 g8 s/n:5cg2374434
please program update filesWhat does tge problem?
Take a full backup of both the BIOS and EC chips first.latest update files for elitebook 840 g8 :
M.2 is worked before unlock the bios.Take a full backup of both the BIOS and EC chips first.
Then program both chips (BIOS and EC) with the latest files that were provided.
After programming the BIOS, DO NOT power on the laptop.
Make sure both chips are fully programmed before turning the system on.
After powering on, wait at least 3–4 minutes.
During the first boot, the system may restart several times or shut down and power on automatically.
Be patient and allow the programming/initialization process to complete.
Most likely, after this process, the BIOS password issue and the other problems you mentioned will be resolved, unless there is another underlying hardware issue.
Overall, these files are your last chance if the problem is firmware-related.
Heyplay999 , Vahab Hemmati , user46647 , Redhat , Admin , Faizal
